Aller au contenu principal
Garmin Nuvi 370 Auxiliary Audio Out Port Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement, Auxiliary Audio Out Port: étape 1, image 1 de 1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 2, image 1 de 3 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 2, image 2 de 3 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 3, image 1 de 2 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 3, image 2 de 2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 4, image 1 de 2 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 4, image 2 de 2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • If nessesary, use tweezers or the spudger for precision.
  5. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 5, image 1 de 2 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 5, image 2 de 2
    Desoldering Pump
    $3.99
    J'achète
    • De-solder the audio out port. Use a soldering iron to melt the solder on each of the leads of the port and a solder extraction tool (not shown), such as a solder sucker or copper braid.
    • Use tweezers to grab the port for greater protection and precision.
  6. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: étape 6, image 1 de 1
    • The audio out port should now be completely separated from all other components.
    • Solder new, functional audio port. Make sure all solder connections are clean.
Matt West
Membre depuis le 04/18/13
31 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-65, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 630
