Aller au contenu principal
Garmin Nuvi 42LM Screen Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 42LM Screen Replacement, Back Cover: étape 1, image 1 de 3 Garmin Nuvi 42LM Screen Replacement, Back Cover: étape 1, image 2 de 3 Garmin Nuvi 42LM Screen Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Screen Replacement: étape 2, image 1 de 3 Garmin Nuvi 42LM Screen Replacement: étape 2, image 2 de 3 Garmin Nuvi 42LM Screen Replacement: étape 2, image 3 de 3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Screen Replacement, Motherboard: étape 3, image 1 de 3 Garmin Nuvi 42LM Screen Replacement, Motherboard: étape 3, image 2 de 3 Garmin Nuvi 42LM Screen Replacement, Motherboard: étape 3, image 3 de 3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Screen Replacement: étape 4, image 1 de 1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Screen Replacement: étape 5, image 1 de 2 Garmin Nuvi 42LM Screen Replacement: étape 5, image 2 de 2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Screen Replacement: étape 6, image 1 de 2 Garmin Nuvi 42LM Screen Replacement: étape 6, image 2 de 2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
  7. Garmin Nuvi 42LM Screen Replacement: étape 7, image 1 de 1
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
  8. Garmin Nuvi 42LM Screen Replacement, Screen: étape 8, image 1 de 2 Garmin Nuvi 42LM Screen Replacement, Screen: étape 8, image 2 de 2
    • Push out the screen by pulling back the black clips.
    • The screen is attached to the motherboard and needs to be replaced with it.
2 autres ont terminé cette réparation.
Elina Zhukov
Membre depuis le 01/18/17
558 Réputation
5 tutoriels rédigés
Un commentaire
Where do I purchase the screen for the Nuvi 42LM?
DR ROGER BROWNE - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 478
