Aller au contenu principal
Garmin Nuvi 56LMT Speaker Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: étape 2, image 1 de 2 Garmin Nuvi 56LMT Speaker Replacement: étape 2, image 2 de 2
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: étape 3, image 1 de 2 Garmin Nuvi 56LMT Speaker Replacement: étape 3, image 2 de 2
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: étape 4, image 1 de 2 Garmin Nuvi 56LMT Speaker Replacement: étape 4, image 2 de 2
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: étape 5, image 1 de 1
Dustin Saxon
Membre depuis le 09/28/17
228 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S3-G5, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 105
