Aller au contenu principal
Garmin Nuvi 65LM Car Charger Fuse Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: étape 1, image 1 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: étape 1, image 2 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: étape 1, image 3 de 3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: étape 2, image 1 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: étape 2, image 2 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: étape 2, image 3 de 3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: étape 3, image 1 de 1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
Kai Ling Liang
Membre depuis le 04/26/15
246 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-3, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 2,077
