Introduction
A step-by-step guide to replacing the antenna in the Garmin Nuvi 680.
Ce dont vous avez besoin
Flip open the antenna on the back of the device.
Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
Remove the antenna.
Presque terminé !
