Introduction
A step-by-step guide to replacing the motherboard in the Garmin Nuvi 680.
  1. Flip open the antenna on the back of the device.
    • Flip open the antenna on the back of the device.
    • Remove the two screws on the antenna cover using a T5 Torx screwdriver.
      • These screws are 4.42 mm long.
  2. Remove the antenna cover.
    • Remove the antenna cover.
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
      • These screws are 10.82 mm long.
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard.
    • Remove the antenna.
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
    • Use a PH1 sized Philips screwdriver to remove the two screws shown.
      • These screws are 6.88 mm long
    • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
    • Use a spudger to lift the edge of the motherboard.
    • Gently unplug the cable for the battery
    • Gently unplug the cable for the speaker.
    • Lift the motherboard out of the outer case.
Chris Marzano
Membre depuis le 20/01/2011
968 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-22, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 3,473
