Aller au contenu principal
  1. At the top of the outer frame, insert the plastic spudger into the groove in the center and lever it gently until it pops out. At the top of the outer frame, insert the plastic spudger into the groove in the center and lever it gently until it pops out. At the top of the outer frame, insert the plastic spudger into the groove in the center and lever it gently until it pops out.
    • At the top of the outer frame, insert the plastic spudger into the groove in the center and lever it gently until it pops out.
  2. Use a Phillips #00 screwdriver to remove all four screws around the screen. Use a Phillips #00 screwdriver to remove all four screws around the screen. Use a Phillips #00 screwdriver to remove all four screws around the screen.
    • Use a Phillips #00 screwdriver to remove all four screws around the screen.
  3. Gently pull from both ends to separate the front and back panels. Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
    • Gently pull from both ends to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Gently unplug the white cable connector using either your fingers or the tweezers. Gently unplug the white cable connector using either your fingers or the tweezers. Gently unplug the white cable connector using either your fingers or the tweezers.
    • Gently unplug the white cable connector using either your fingers or the tweezers.
  5. Carefully expose both halves of the device.
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
2 autres ont terminé cette réparation.
Adrian Leon
Membre depuis le 07/10/2010
173 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 22-1, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,879
