Introduction
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
Outils
Pièces
Aucune pièce spécifiée.
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
Presque terminé !
