Aller au contenu principal
Garmin StreetPilot c320 Rear Case Assembly Replacement
Ce dont vous avez besoin
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: étape 1, image 1 de 2 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: étape 1, image 2 de 2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: étape 2, image 1 de 2 Garmin StreetPilot c320 Rear Case Assembly Replacement: étape 2, image 2 de 2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: étape 3, image 1 de 1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Andrew Burman
Membre depuis le 01/18/12
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-19, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,369
