Introduction
This guide will provide step by step instructions to enable you to safely and effectively disassemble your Garmin StreetPilot and remove and replace the screen, then reassemble your device.
  1. Use a plastic spudger tool to remove the plastic frame. Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out. Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
    • Use a plastic spudger tool to remove the plastic frame.
    • Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
  2. Use a phillips head screw driver to remove all four screws in the corners around the screen. Set the screws aside for later. Set the screws aside for later.
    • Use a phillips head screw driver to remove all four screws in the corners around the screen.
    • Set the screws aside for later.
  3. Gently pull from both ends to separate the front panel from the back. Do not force the pieces apart wider than the length of the connecting wires or you will damage the wiring.
    • Gently pull from both ends to separate the front panel from the back.
    • Do not force the pieces apart wider than the length of the connecting wires or you will damage the wiring.
  4. Locate the white wire clip.  Gently unplug it using either your fingers or tweezers. Locate the white wire clip.  Gently unplug it using either your fingers or tweezers. Locate the white wire clip.  Gently unplug it using either your fingers or tweezers.
    • Locate the white wire clip. Gently unplug it using either your fingers or tweezers.
  5. Carefully expose both halves of the device.
    • Carefully expose both halves of the device.
    • Be sure to not pull the two halves apart too hard to avoid damaging the black wire.
  6. Locate the three screws holding the motherboard in place. Remove screws. Set screws aside in a safe place.
    • Locate the three screws holding the motherboard in place.
    • Remove screws.
    • Set screws aside in a safe place.
  7. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  8. Use Spudger to lift up motherboard.
    • Use Spudger to lift up motherboard.
  9. To remove the ribbon cable, lift the black latch using the spudger tool. Separate the connection using either your fingers, tweezers, or the spudger. Separate the connection using either your fingers, tweezers, or the spudger.
    • To remove the ribbon cable, lift the black latch using the spudger tool.
    • Separate the connection using either your fingers, tweezers, or the spudger.
  10. Slide the spudger tool under the first flexible tab located on the right side of the bottom of the screen. The tab is denoted by a red box in the photo.
    • Slide the spudger tool under the first flexible tab located on the right side of the bottom of the screen.
    • The tab is denoted by a red box in the photo.
    • There are two tabs at the top of the screen that are not flexible
    • Rotate the spudger outward until the tab is no longer holding the screen.
    • Push the screen out from the front.
  11. Find the second flexible tab near the screen's wires and slide spudger under tab.
    • Find the second flexible tab near the screen's wires and slide spudger under tab.
    • Rotate spudger outward until the tab is no longer holding the screen.
  12. Separate the screen from the front cover.
    • Separate the screen from the front cover.
  13. Have your new screen ready to insert, making sure it is fully unwrapped.
    • Have your new screen ready to insert, making sure it is fully unwrapped.
    • Find the tabs used to secure the screen as highlighted in the photo.
    • Slide the bottom of the screen under the permanent tabs.
    • The permanent tabs are denoted by blue boxes in the photo.
    • Use the spudger tool to raise the flexible tabs in order to reinsert the screen completely into the front cover.
  14. Reinsert the ribbon cable into the slot you removed it from. Lower the black latch using the spudger tool.
    • Reinsert the ribbon cable into the slot you removed it from.
    • Lower the black latch using the spudger tool.
  15. Reattach the motherboard with the three screws you removed previously.
    • Reattach the motherboard with the three screws you removed previously.
    • Use the silver screws.
  16. Locate the white wire clip. Plug it back in. Plug it back in.
    • Plug it back in.
  17. Screw the front panel back onto the base using the four screws you removed in step 2.
    • Screw the front panel back onto the base using the four screws you removed in step 2.
    • Use the black screws.
  18. Gently pop the plastic frame back into place.
    • Gently pop the plastic frame back into place.
Michael
Membre depuis le 07/10/2010
104 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 22-1, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,966
