Ce dont vous avez besoin
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
Rotate the spudger outward until the tabs are no longer holding the screen.
When reassembling, slide the bottom of the screen under the two permanent tabs.
Push the screen out from the front.
