Aller au contenu principal
Garmin StreetPilot c330 Screen Replacement
Ce dont vous avez besoin
  1. Garmin StreetPilot c330 Screen Replacement, Outer Casing: étape 1, image 1 de 3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: étape 1, image 2 de 3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: étape 1, image 3 de 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Screen Replacement: étape 2, image 1 de 3 Garmin StreetPilot c330 Screen Replacement: étape 2, image 2 de 3 Garmin StreetPilot c330 Screen Replacement: étape 2, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Screen Replacement: étape 3, image 1 de 2 Garmin StreetPilot c330 Screen Replacement: étape 3, image 2 de 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Screen Replacement: étape 4, image 1 de 3 Garmin StreetPilot c330 Screen Replacement: étape 4, image 2 de 3 Garmin StreetPilot c330 Screen Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Screen Replacement: étape 5, image 1 de 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Screen Replacement, Screen: étape 6, image 1 de 3 Garmin StreetPilot c330 Screen Replacement, Screen: étape 6, image 2 de 3 Garmin StreetPilot c330 Screen Replacement, Screen: étape 6, image 3 de 3
    • Remove the three screws holding the motherboard in place.
  7. Garmin StreetPilot c330 Screen Replacement: étape 7, image 1 de 1
    • Use the spudger to lift up the motherboard.
  8. Garmin StreetPilot c330 Screen Replacement: étape 8, image 1 de 3 Garmin StreetPilot c330 Screen Replacement: étape 8, image 2 de 3 Garmin StreetPilot c330 Screen Replacement: étape 8, image 3 de 3
    J'achète
    • To remove the ribbon cable, lift the black latch using the spudger tool.
    • Separate the connection using either your fingers, tweezers, or the spudger.
  9. Garmin StreetPilot c330 Screen Replacement: étape 9, image 1 de 2 Garmin StreetPilot c330 Screen Replacement: étape 9, image 2 de 2
    • Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
    • Rotate the spudger outward until the tabs are no longer holding the screen.
    • When reassembling, slide the bottom of the screen under the two permanent tabs.
    • Push the screen out from the front.
  10. Garmin StreetPilot c330 Screen Replacement: étape 10, image 1 de 1
    • Separate the screen from the front cover.
Adrian Leon
Membre depuis le 10/07/10
173 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 22-1, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 1,559
