Ce dont vous avez besoin
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
Carefully peel the metal bracket away from the battery.
Pull the battery away from the back cover.
Desolder the wires from the speakers using a soldering iron.
Carefully use the spudger to pry the speakers from the outer casing.
Once removed, you may use a soldering iron to remove the wires from the speakers.
