Aller au contenu principal
Garmin fenix 6X Sapphire Back Cover Replacement
Ce dont vous avez besoin
  1. Garmin fenix 6X Sapphire Back Cover Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the watch so the face is down.
    • Remove the five 6 mm T5 Torx screws on the back of the watch.
  2. Garmin fenix 6X Sapphire Back Cover Replacement: étape 2, image 1 de 3 Garmin fenix 6X Sapphire Back Cover Replacement: étape 2, image 2 de 3 Garmin fenix 6X Sapphire Back Cover Replacement: étape 2, image 3 de 3
    • Use a spudger to pry the back cover of the watch off by placing it under the seam of the back case.
    • The back cover is glued on and may be difficult to remove. It might help to heat the back cover before prying in order to soften the glue. If doing so, be careful to not burn yourself.
    • This step requires a good bit of force to pry or apply heat back cover off because the back cover is glued. Be careful not to the break cover from too much force.
matthew long
Membre depuis le 02/22/22
522 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-5, Hunter Spring 2022 Membre de l'équipe Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 24
30 derniers jours : 75
Total : 2,124
