Aller au contenu principal
Garmin fenix 6X Sapphire Battery Replacement
Ce dont vous avez besoin
  1. Garmin fenix 6X Sapphire Battery Replacement, Display: étape 1, image 1 de 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Battery Replacement: étape 2, image 1 de 2 Garmin fenix 6X Sapphire Battery Replacement: étape 2, image 2 de 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
  3. Garmin fenix 6X Sapphire Battery Replacement, Motherboard: étape 3, image 1 de 1
    • Remove the four 5mm silver screws on the outer part of the motherboard using the T5 Torx screwdriver.
    • Pull the motherboard out carefully as it is connected on the other side by another ribbon connector.
  4. Garmin fenix 6X Sapphire Battery Replacement: étape 4, image 1 de 3 Garmin fenix 6X Sapphire Battery Replacement: étape 4, image 2 de 3 Garmin fenix 6X Sapphire Battery Replacement: étape 4, image 3 de 3
    • Unlock the ZIF connector and remove the ribbon connector from the back of the motherboard.
    • A Jimmy can be used if you have trouble prying the piece with your fingers.
    • Be careful not to pull on the ribbon as it could tear.
    • Remove the motherboard.
  5. Garmin fenix 6X Sapphire Battery Replacement, Battery: étape 5, image 1 de 3 Garmin fenix 6X Sapphire Battery Replacement, Battery: étape 5, image 2 de 3 Garmin fenix 6X Sapphire Battery Replacement, Battery: étape 5, image 3 de 3
    • To remove the battery, you will need to pry it from the glue that holds it in the bottom of the watch using a jimmy.
    • Be extremely careful when prying the battery as there is a very delicate ribbon underneath the battery.
    • When the battery is disconnected from the glue, slowly pull it up out of the watch, while keeping in mind that it is connected to some leads.
  6. Garmin fenix 6X Sapphire Battery Replacement: étape 6, image 1 de 2 Garmin fenix 6X Sapphire Battery Replacement: étape 6, image 2 de 2
    • The battery has a few wires that are soldered into the watch leads. You will need to cut the wires using utility scissors so that you can attach a new battery.
    • When the wires have been cut, remove the battery.
    • The wires on the new battery should be soldered to the watch leads.
4 autres ont terminé cette réparation.
matthew long
Membre depuis le 02/22/22
522 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-5, Hunter Spring 2022 Membre de l'équipe Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 membres
8 tutoriels rédigés
2 commentaires
Es wäre viel einfacher den Akku von der Rückseite zu entfernen. So kann die Elektronik im Gehäuse gelassen werden.
iSchmitt Repair - Réponse
Bei meiner Fenix 6 Titan Saphire vom Dezember 2019, ist die Batterie nicht mehr verlötet und der Stecker der Ersatzbatterie passt wunderbar, obwohl das Kabel etwas länger war. Die Platine ist außerdem nur mit 2 Schrauben gesichert und an der oberen rechten Ecke mit etwas Kleber am Gehäuse fixiert.
Joerg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 33
7 derniers jours : 248
30 derniers jours : 969
Total : 20,612
