Aller au contenu principal
Garmin fenix 6X Sapphire Display Replacement
Ce dont vous avez besoin
  1. Garmin fenix 6X Sapphire Display Replacement, Display: étape 1, image 1 de 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Display Replacement: étape 2, image 1 de 2 Garmin fenix 6X Sapphire Display Replacement: étape 2, image 2 de 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
5 autres ont terminé cette réparation.
matthew long
Membre depuis le 02/22/22
522 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-5, Hunter Spring 2022 Membre de l'équipe Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 membres
8 tutoriels rédigés
2 commentaires
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - Réponse
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 35
30 derniers jours : 194
Total : 7,164
