Aller au contenu principal
Garmin vívofit 2 Batteries Replacement
Ce dont vous avez besoin
  1. Garmin vívofit 2 Batteries Replacement, Wristband: étape 1, image 1 de 2 Garmin vívofit 2 Batteries Replacement, Wristband: étape 1, image 2 de 2
    • Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
  2. Garmin vívofit 2 Batteries Replacement, Batteries: étape 2, image 1 de 1
    • Remove the four 3.8mm Phillips #00 screws holding the device together.
  3. Garmin vívofit 2 Batteries Replacement: étape 3, image 1 de 1
    • With the screws removed from the device, take the cover off the top of the device, revealing the batteries inside.
  4. Garmin vívofit 2 Batteries Replacement: étape 4, image 1 de 1
    • With the cover removed, take out the two batteries currently in the device. Take note of which side of the battery is facing which way in the device. Battery removal can usually be accomplished with your fingers. If not, carefully use a nylon spudger to pull up one edge of the battery, allowing you to remove that battery.
James Hickey
Membre depuis le 03/26/18
290 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G2, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 3,390
