Aller au contenu principal
Gas Grill Ceramic Briquettes Replacement
Ce dont vous avez besoin
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: étape 1, image 1 de 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: étape 1, image 2 de 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: étape 1, image 3 de 3
    • Carefully lift grill plate located above briquettes
    • Make sure the gas grill is off and the propane is turned off before removing the grill plate
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: étape 2, image 1 de 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: étape 2, image 2 de 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: étape 2, image 3 de 3
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: étape 3, image 1 de 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: étape 3, image 2 de 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: étape 3, image 3 de 3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
    • A small container is recommended to keep the screws together
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: étape 4, image 1 de 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: étape 4, image 2 de 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: étape 4, image 3 de 3
    • Using your hands, gently unscrew washers from the back of the casing.
    • A small container is recommended to keep the washers together
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: étape 5, image 1 de 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: étape 5, image 2 de 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: étape 5, image 3 de 3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: étape 6, image 1 de 1
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: étape 7, image 1 de 1
    • Take 16 new ceramic briquettes out and carefully align them inside the casing.
    • Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
3 autres ont terminé cette réparation.
emma
Membre depuis le 01/27/16
173 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 Membre de l'équipe USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016
USFSM-STEWART-S16S1G3
5 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 37
Total : 4,107
