Introduction
The tread may be damaged or severely worn when inspecting the security wheels on the Home Depot wire shopping carts. The Gatekeeper wheels are designed with replaceable tread.
Using two 7/16th box wrenches, loosen and remove the nut, washer and bolt. Set aside to reuse.
Using a T-15 Torx bit, remove the five screws, then pry the old tread off the wheel.
Line up the new tread on the wheel, then insert five new screws using a T-15 Torx bit
Replace the nut, washer and bolt that was removed in step 1
