Introduction
If your Gateway GWTC116-2BL laptop is experiencing issues with its daughterboard, replacing it might be necessary. The daughterboard is an essential component that connects the motherboard to other peripherals, such as the keyboard, touchpad, and USB ports. Faulty daughterboards can cause several problems, including malfunctioning laptop peripherals. Replacing a Gateway GWTC116-2BL daughterboard is a simple process that involves a few steps. In this guide, we'll outline the steps you need to take to replace the daughterboard and get your laptop functioning normally again.
Ce dont vous avez besoin
Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
Peel off the yellow piece of tape that is placed over the daughterboard.
