Aller au contenu principal
Introduction
This step-by-step guide illustrates how to replace the CD drive on the Gateway MD2614u.
  1. Locate the circled screw.
    • Locate the circled screw.
    • Carefully unscrew, making sure not to strip out the screw.
  2. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  3. Use any tool with a flat edge in order to pry out the CD-Drive, preferably a plastic opening tool.
    • Use any tool with a flat edge in order to pry out the CD-Drive, preferably a plastic opening tool.
  4. Once the CD drive has been pried out enough, you can pull it out without damaging the other components.
    • Once the CD drive has been pried out enough, you can pull it out without damaging the other components.
Nelson
Membre depuis le 11/03/2014
201 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Calloway Fall 2012 Membre de l'équipe UMass Dartmouth, Team 4-2, Calloway Fall 2012
UMASSD-CALLOWAY-F12S4G2
1 membre
2 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 232
