Introduction
This guide will teach you how to remove your RAM modules. Upgrading RAM is a common practice among users. One thing to note is that if you want to only remove the lower RAM module, you have to remove the top one first.
Ce dont vous avez besoin
Slide the long slider towards the unlocked lock icon.
This slider is spring loaded and may require a little force.
If done correctly, a click will be heard and the battery will be slightly raised.
Use the phillips head screwdriver to remove the five screws holding the back plate.
Place fingers under back plate via the indentation and lift upwards to remove.
Push the upper RAM module's two pins outwards at the same time.
If done correctly, the module should have lifted.
Grab onto the module and pull away in a straight direction.
Push the lower RAM module's two pins outwards at the same time.
Like removing the upper module, grab the module and pull away in a straight direction.
