Aller au contenu principal
Gateway NV53A24u Keyboard Replacement
Ce dont vous avez besoin
  1. Gateway NV53A24u Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Before removing the keyboard, turn off the computer and open it.
  2. Gateway NV53A24u Keyboard Replacement: étape 2, image 1 de 2 Gateway NV53A24u Keyboard Replacement: étape 2, image 2 de 2
    • Use a spudger to gently pry out the keyboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
    • There are small metal tabs holding it in place beneath the bezel. Using your tool, you should be able to easily pop the keyboard out.
  3. Gateway NV53A24u Keyboard Replacement: étape 3, image 1 de 2 Gateway NV53A24u Keyboard Replacement: étape 3, image 2 de 2
    • Once the keyboard is removed, you may have to remove the connecting ribbon cable, but it easily pulls out.
tannerroan
Membre depuis le 10/11/16
333 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-5, Leahy Fall 2016
USFT-LEAHY-F16S1G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 490
