Introduction
The battery is a component that will power your device. This guide will go over how to remove and replace the battery for the P-6831FX.
Turn your laptop upside down and locate the 1st unlocking switch.
  • Turn your laptop upside down and locate the 1st unlocking switch.
  • Make sure to unplug your laptop charger, as removing the battery while the device is charging may damage the battery and or the charger.
Ajouter un commentaire
Put the switch from the locked position to the unlocked position.
  • Put the switch from the locked position to the unlocked position.
  • Slide the lock to the right to unlock the battery from the device.
  • While holding the 2nd lock in the unlocked position, pull the battery away from the laptop.
Justin Freitas
Membre depuis le 19/03/2018
294 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G5, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G5, Peak Spring 2018
UMASSD-PEAK-S18S3G5
2 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 55
