Aller au contenu principal
Gateway SA1 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Gateway SA1 Cooling Fan Replacement, Battery: étape 1, image 1 de 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: étape 2, image 1 de 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: étape 3, image 1 de 2 Gateway SA1 Cooling Fan Replacement, Cooling Fan: étape 3, image 2 de 2
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: étape 4, image 1 de 1
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: étape 5, image 1 de 2 Gateway SA1 Cooling Fan Replacement: étape 5, image 2 de 2
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: étape 6, image 1 de 1
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: étape 7, image 1 de 1
    • You are now able to remove the cooling fan.
6 autres ont terminé cette réparation.
Diego Carteno
Membre depuis le 04/15/10
258 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 24-20, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 13,427
