Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Installing upgraded memory.
  1. Move the latch to the right of the battery to unlock.
    • Move the latch to the right of the battery to unlock.
  2. Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Loosen the indicated Philips screw that connects the memory bay cover to the casing. The indicated Philips screw does not come out of the cover.
    • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
    • The indicated Philips screw does not come out of the cover.
  5. Lift and remove the cover using the spudger. Lift and remove the cover using the spudger.
    • Lift and remove the cover using the spudger.
  6. Gently press the clip outwards. The module will tilt up and can be pulled out of the slot.
    • Gently press the clip outwards.
    • The module will tilt up and can be pulled out of the slot.
    • There may be another memory module underneath so be sure to remove both.
  7. To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • Place the first module into the bottom slot then the next module into the top slot.
    • These slots are keyed so verify that you are sliding the module in one direction.
    • Verify that the new memory modules are designed for your specific Gateway Laptop.
3 autre(s) ont terminé cette réparation.
Diego Carteno
Membre depuis le 15/04/2010
252 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 24-20, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 5,031
