Introduction
Follow this replacement guide to replace a malfunctioning diskette drive.
Floppy disks are used to install software, access data, and run applications. They are integral to the maintenance and upkeep of your device. If your Gateway Solo 1200 is failing to read floppy disks, there could be an issue with your diskette drive. Use this guide to replace the diskette drive in Gateway Solo 1200.
Ce dont vous avez besoin
Locate the battery latch on the bottom of the laptop.
Release the latch by pressing it with your thumb and sliding it to the right.
Slide the battery out of its compartment.
Turn the device so the back is facing you.
Unscrew the 2 mm screws with a Phillips #0 screwdriver.
Rotate the device so the battery compartment is located at the bottom.
Locate the diskette drive directly above the battery compartment on the left side.
