Introduction
The circuit board of the car delivers information from the remote to the motors so the car can move. If the circuit board has a broken component and no longer works, it's far easier to replace the whole board rather than trying to find the broken component. The following steps will show you how to replace the circuit board of the car.
Note: This guide will involve soldering. For information on how to solder, please visit iFixit's Soldering Skills page.
Ce dont vous avez besoin
Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
Gently lift the battery cover from the car to expose the batteries.
Flip the car over and remove the four 5mm Phillips #0 screws that hold the shell to the car chassis.
Flip the car over again to its upright position and vertically lift the shell from the car.
Unscrew and remove the 5mm Phillips #0 screw located at the center of the wheel while holding the wheel still.
Slide the wheel off of the axle.
Repeat the previous steps for the other rear wheel.
Remove the eight 5mm Phillips #0 screws located on the top of the motor/circuit board enclosure.
Vertically lift the motor/circuit board enclosure from the car chassis.
Unscrew the two 5mm Phillips #0 screws that hold the circuit board to the casing.
2 autres ont terminé cette réparation.
