Introduction
If the motherboard is not operating correctly, use this guide to replace the motherboard.
Ce dont vous avez besoin
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
Remove the wire from the bottom left of the motherboard by lifting it away from the device.
Remove the 2mm T3 screw in the upper left corner of the motherboard.
