Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will explain how to replace the power supply cable of the General Electric Bagel Switch 4-Slice toaster.
  1. Unplug the toaster from the electrical outlet.
    • Unplug the toaster from the electrical outlet.
  2. Remove the two levers and four dials by pulling them out directly towards you. Removing these components may require some force, but they will release.
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. Look for the plastic clips on the back side of the toaster.
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
  4. Flip the toaster over so that the bottom plate is facing up.
    • Flip the toaster over so that the bottom plate is facing up.
  5. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  6. Remove the four screws from the bottom of the toaster. Remove the four screws from the bottom of the toaster.
    • Remove the four screws from the bottom of the toaster.
    • Carefully separate the bottom plate from the metal components inside the toaster.
  7. Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
    • Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
  8. Pull the power supply cord through the bottom plate of the toaster.
    • Pull the power supply cord through the bottom plate of the toaster.
    • Insert the end of the new power supply cable through the hole in the bottom plate.
  9. Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
    • Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
    • Splice the stripped ends of wire together using a wire cap.
Ron Gajdos
Membre depuis le 16/10/2013
307 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 Membre de l'équipe UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G4
3 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 344
