Aller au contenu principal
General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement
Ce dont vous avez besoin
  1. General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the cable end cover: étape 1, image 1 de 2 General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the cable end cover: étape 1, image 2 de 2
    • Turn off the drain cleaner and disconnect it from power before beginning any maintenance.
    • Slide the rubber cable cover off of the end of the cable.
  2. General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Loosen the front assembly screws: étape 2, image 1 de 1
    • Use a flathead screwdriver to loosen the three screws around the edge of the front assembly.
  3. General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the front assembly: étape 3, image 1 de 3 General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the front assembly: étape 3, image 2 de 3 General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the front assembly: étape 3, image 3 de 3
    • Pull the front assembly off of the drain cleaner and slide it over the cable to remove it.
    • During reassembly, make sure the three screws on the front assembly line up with the slots on both the metal cable container back and the plastic cable container.
Adam O'Camb
Membre depuis le 04/11/15
197 111 Réputation
416 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 24
Total : 1,060
