Aller au contenu principal
Generic TV Remote IR LED Replacement
Ce dont vous avez besoin
  1. Generic TV Remote IR LED Replacement, IR LED: étape 1, image 1 de 2 Generic TV Remote IR LED Replacement, IR LED: étape 1, image 2 de 2
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
  2. Generic TV Remote IR LED Replacement: étape 2, image 1 de 3 Generic TV Remote IR LED Replacement: étape 2, image 2 de 3 Generic TV Remote IR LED Replacement: étape 2, image 3 de 3
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
  3. Generic TV Remote IR LED Replacement: étape 3, image 1 de 1
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
  4. Generic TV Remote IR LED Replacement: étape 4, image 1 de 1
    • Desolder the broken LED using a soldering iron and desoldering braid.
  5. Generic TV Remote IR LED Replacement: étape 5, image 1 de 1
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
  6. Generic TV Remote IR LED Replacement: étape 6, image 1 de 3 Generic TV Remote IR LED Replacement: étape 6, image 2 de 3 Generic TV Remote IR LED Replacement: étape 6, image 3 de 3
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
  7. Generic TV Remote IR LED Replacement: étape 7, image 1 de 1
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
2 autres ont terminé cette réparation.
Geoffrey Smith
Membre depuis le 06/01/16
151 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 84
Total : 12,706
