Aller au contenu principal
Giant Reign 2 Rear Shock Replacement
Ce dont vous avez besoin
  1. Giant Reign 2 Rear Shock Replacement, Rear Shock: étape 1, image 1 de 1
    • Orient the bike upside down.
  2. Giant Reign 2 Rear Shock Replacement: étape 2, image 1 de 1
    • Remove the 10mm screw and take the bash guard off of the frame.
  3. Giant Reign 2 Rear Shock Replacement: étape 3, image 1 de 1
    • Remove the 65mm screw that connects the bottom of the shock to the frame.
    • Use a wrench to hold the other side.
  4. Giant Reign 2 Rear Shock Replacement: étape 4, image 1 de 1
    • Remove the 40mm screw that connects the shock to the link arm of the suspension.
  5. Giant Reign 2 Rear Shock Replacement: étape 5, image 1 de 2 Giant Reign 2 Rear Shock Replacement: étape 5, image 2 de 2
    • Push the shock out of the brackets mounting it to the frame and suspension arm.
    • This may require some force and slight wiggling from side to side.
Andrew Krasts
Membre depuis le 10/05/12
302 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-14, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 membres
10 tutoriels rédigés
Un commentaire
Which valve stem is the one to put air into the shock there's one on the bottom one on top and adjustment knob right next to the top one
Ron Hobson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 28
Total : 4,933
