Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Gigabyte RTX 3060 GPU Fan Replacement
Ce dont vous avez besoin
  1. Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: étape 1, image 1 de 3 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: étape 1, image 2 de 3 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: étape 1, image 3 de 3
    • Remove the four springs screws attached to the thermal plate on the GPU using a Phillips #00 screwdriver.
    • Remove the two screws from the right side using a Phillips #00 screwdriver.
    • Remove the two screws from the left side using a Phillips #00 screwdriver.
  2. Gigabyte RTX 3060 GPU Fan Replacement: étape 2, image 1 de 3 Gigabyte RTX 3060 GPU Fan Replacement: étape 2, image 2 de 3 Gigabyte RTX 3060 GPU Fan Replacement: étape 2, image 3 de 3
    • Lift the backplate off after the screws are removed.
    • You will notice both sides of the card have a cable holding the cover and the main GPU board.
    • Carefully remove the connector at the top of the GPU (the side with GEFORCE RTX like on the picture) connecting the GPU board and the fan cover.
  3. Gigabyte RTX 3060 GPU Fan Replacement: étape 3, image 1 de 2 Gigabyte RTX 3060 GPU Fan Replacement: étape 3, image 2 de 2
    • Flip over the GPU cover.
    • Remove the four screws using a Phillips #00 screwdriver.
  4. Gigabyte RTX 3060 GPU Fan Replacement: étape 4, image 1 de 2 Gigabyte RTX 3060 GPU Fan Replacement: étape 4, image 2 de 2
    • Set the thermal system to the side.
    • Flip over the GPU cover with the fans and find the fan that needs to be replaced.
    • There are three screws underneath the fan blades. Look at the second picture as a reference for one of the screws. Remove all three using a Phillips #00 screwdriver.
  5. Gigabyte RTX 3060 GPU Fan Replacement: étape 5, image 1 de 2 Gigabyte RTX 3060 GPU Fan Replacement: étape 5, image 2 de 2
    • Remove the connector associated with the fan.
    • Pull the fan out with its connector cable intact.
  6. Gigabyte RTX 3060 GPU Fan Replacement: étape 6, image 1 de 1
    • Grab your replacement fan for the Gigabyte RTX 3060.
    • The repair can be completed with the replacement fan by reversing the steps previously shown.
3 autres ont terminé cette réparation.
sanskar1016
Membre depuis le 10/25/23
223 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-22, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 4-22, Kershman Fall 2023
CSULA-KERSHMAN-F23S4G22
1 membre
4 tutoriels rédigés
1 commentaire de tutoriel
и потом через время карта сломается. это написано делитантом для делитантов. ни слова о замене термопасты. собрать в обратном порядке, и не заменить термопасту, это трешь. не рекомендую это никому.
Николай Тиссин - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 127
30 derniers jours : 599
Total : 10,297
