Aller au contenu principal
GoPro HD Hero2 Motherboard Assembly Replacement
Ce dont vous avez besoin
  1. GoPro HD Hero2 Motherboard Assembly Replacement, Back Cover: étape 1, image 1 de 2 GoPro HD Hero2 Motherboard Assembly Replacement, Back Cover: étape 1, image 2 de 2
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. GoPro HD Hero2 Motherboard Assembly Replacement, Battery: étape 2, image 1 de 2 GoPro HD Hero2 Motherboard Assembly Replacement, Battery: étape 2, image 2 de 2
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. GoPro HD Hero2 Motherboard Assembly Replacement: étape 3, image 1 de 1
    • Remove the battery from the case.
  4. GoPro HD Hero2 Motherboard Assembly Replacement, Rear Case: étape 4, image 1 de 1
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  5. GoPro HD Hero2 Motherboard Assembly Replacement: étape 5, image 1 de 2 GoPro HD Hero2 Motherboard Assembly Replacement: étape 5, image 2 de 2
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  6. GoPro HD Hero2 Motherboard Assembly Replacement: étape 6, image 1 de 2 GoPro HD Hero2 Motherboard Assembly Replacement: étape 6, image 2 de 2
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  7. GoPro HD Hero2 Motherboard Assembly Replacement: étape 7, image 1 de 2 GoPro HD Hero2 Motherboard Assembly Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  8. GoPro HD Hero2 Motherboard Assembly Replacement: étape 8, image 1 de 3 GoPro HD Hero2 Motherboard Assembly Replacement: étape 8, image 2 de 3 GoPro HD Hero2 Motherboard Assembly Replacement: étape 8, image 3 de 3
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
  9. GoPro HD Hero2 Motherboard Assembly Replacement, Motherboard Assembly: étape 9, image 1 de 1
    • Remove the three screws securing the motherboard assembly to the front case:
    • Two 10.8 mm Phillips #00 screws.
    • One 4.8 mm Phillips #00 screw.
  10. GoPro HD Hero2 Motherboard Assembly Replacement: étape 10, image 1 de 2 GoPro HD Hero2 Motherboard Assembly Replacement: étape 10, image 2 de 2
    • Gently grab the edges of the motherboard assembly and lift it out of the front case.
8 autres ont terminé cette réparation.
David Hodson
Membre depuis le 04/13/10
154 625 Réputation
127 tutoriels rédigés
2 commentaires de tutoriel
Where exactly do you buy the replacement boards? I cant find them anywhere..
Lauren Ashleyy - Réponse
Hello. GoPro HERO2 there. overheating after doing update. 10-15 minutes after closing. overheating.
coskunadnan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 33
Total : 18,739
