Introduction
The image sensor is a vital part of your GoPro. However, don't fear if it has broken, this guide will bring your device back to life!
Ce dont vous avez besoin
Push the tab on the back of the device left to remove the plate covering the battery.
Insert a plastic opening tool in between the front face plate and the black housing.
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
4 autres ont terminé cette réparation.
