Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
  1. Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off. Use the tweezers to lift the faceplate  from the rest of the device. The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. Using a #00 Phillips head screwdriver, remove the following screws: One 4.6 mm screw
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection. Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard. The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. Using a plastic opening tool, separate the camera sensor's connector from the motherboard. Using a plastic opening tool, separate the camera sensor's connector from the motherboard. Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor. Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor. Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
  7. Using a #00 Phillips head screwdriver, remove the following screws: Three 2 mm screw
    • Three 2 mm screw
  8. Lift the lens from the front housing.
    • Lift the lens from the front housing.
5 autre(s) ont terminé cette réparation.
Thomas Sullivan
Membre depuis le 20/02/2017
580 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 membres
6 tutoriels rédigés
Between step 6 and step 7, you skipped a really important step…
Matthew Mulholland - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 31
Total : 3,301
