Aller au contenu principal
GoPro Karma Arms Replacement
Ce dont vous avez besoin
  1. GoPro Karma Arms Replacement, Battery: étape 1, image 1 de 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: étape 2, image 1 de 3 GoPro Karma Arms Replacement, Stabilizer: étape 2, image 2 de 3 GoPro Karma Arms Replacement, Stabilizer: étape 2, image 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: étape 3, image 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: étape 4, image 1 de 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: étape 5, image 1 de 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: étape 6, image 1 de 2 GoPro Karma Arms Replacement: étape 6, image 2 de 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: étape 7, image 1 de 1
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: étape 8, image 1 de 2 GoPro Karma Arms Replacement: étape 8, image 2 de 2
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: étape 9, image 1 de 3 GoPro Karma Arms Replacement: étape 9, image 2 de 3 GoPro Karma Arms Replacement: étape 9, image 3 de 3
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: étape 10, image 1 de 2 GoPro Karma Arms Replacement: étape 10, image 2 de 2
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
Kyle Hoff
Membre depuis le 04/23/18
141 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 membres
6 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 2,239
