Aller au contenu principal
GoPro Karma Harness Replacement
Ce dont vous avez besoin
  1. GoPro Karma Harness Replacement, Stabilizer: étape 1, image 1 de 3 GoPro Karma Harness Replacement, Stabilizer: étape 1, image 2 de 3 GoPro Karma Harness Replacement, Stabilizer: étape 1, image 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Harness Replacement: étape 2, image 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  3. GoPro Karma Harness Replacement, Harness: étape 3, image 1 de 3 GoPro Karma Harness Replacement, Harness: étape 3, image 2 de 3 GoPro Karma Harness Replacement, Harness: étape 3, image 3 de 3
    • Place finger on the tab to open the harness and remove the camera.
    • Be sure to pull the camera straight out lest you damage the connectors.
  4. GoPro Karma Harness Replacement: étape 4, image 1 de 1
    • Using a Hex 2.0mm screwdriver, remove the two 12 mm hex screws closest to the harness.
  5. GoPro Karma Harness Replacement: étape 5, image 1 de 3 GoPro Karma Harness Replacement: étape 5, image 2 de 3 GoPro Karma Harness Replacement: étape 5, image 3 de 3
    • Pull the harness off of the stabilizer.
    • Be sure to pull the harness straight off lest you damage the connector.
Max Verspieren
Membre depuis le 04/19/18
97 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 20
Total : 1,196
