Aller au contenu principal
GoPro Karma Landing Gear Replacement
Ce dont vous avez besoin
  1. GoPro Karma Landing Gear Replacement, Battery: étape 1, image 1 de 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: étape 2, image 1 de 3 GoPro Karma Landing Gear Replacement, Stabilizer: étape 2, image 2 de 3 GoPro Karma Landing Gear Replacement, Stabilizer: étape 2, image 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: étape 3, image 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: étape 4, image 1 de 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: étape 5, image 1 de 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: étape 6, image 1 de 2 GoPro Karma Landing Gear Replacement: étape 6, image 2 de 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
Jay Ingram
Membre depuis le 04/19/18
334 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 11
Total : 594
