Aller au contenu principal
Goal Zero Rock Out 2 #94007 Speaker Repair
Ce dont vous avez besoin
  1. Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: étape 1, image 1 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: étape 1, image 2 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: étape 1, image 3 de 3
    • Power off your speaker before beginning disassembly.
    • Use a 2 mm Allen Key to remove eight 13 mm screws from the faceplate.
    • Use a spudger to remove the faceplate and set it aside.
  2. Goal Zero Rock Out 2 #94007 Speaker Repair: étape 2, image 1 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 2, image 2 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 2, image 3 de 3
    • Remove the gray center piece and yellow rubber lining.
  3. Goal Zero Rock Out 2 #94007 Speaker Repair: étape 3, image 1 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 3, image 2 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 3, image 3 de 3
    • Use a Phillips #0 screwdriver to remove four 12 mm screws from the speaker body.
    • Unzip the speaker case.
    • Turn the the speaker over so the bottom is facing up.
  4. Goal Zero Rock Out 2 #94007 Speaker Repair: étape 4, image 1 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 4, image 2 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 4, image 3 de 3
    • Remove speaker from cloth case.
  5. Goal Zero Rock Out 2 #94007 Speaker Repair: étape 5, image 1 de 2 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 5, image 2 de 2
    • Hold the speaker and gently separate the two parts.
    • Don't yank or pull it apart as the two halves are connected by cables.
  6. Goal Zero Rock Out 2 #94007 Speaker Repair: étape 6, image 1 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 6, image 2 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 6, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the four 12 mm screws securing the center resonator.
    • Carefully remove center resonator from the enclosure.
  7. Goal Zero Rock Out 2 #94007 Speaker Repair: étape 7, image 1 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 7, image 2 de 3 Goal Zero Rock Out 2 #94007 Speaker Repair: étape 7, image 3 de 3
    • This step requires soldering. Soldering can cause injuries such as burns to the skin. It can also produce fumes that are harmful so working in a well-ventilated area is advised.
    • Use wire strippers to remove about 6 mm of insulation from the detached speaker wire.
    • Set the soldering iron to 350 degrees.
    • Add solder to the tip of the iron and then touch the tip to exposed wire.
    • Join the wire with the electrical contact on the speaker.
Ricardo Arevalo Castaneda
Membre depuis le 03/05/24
157 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 8-6, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 8-6, Grodsky Spring 2024
CSULA-GRODSKY-S24S8G6
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 32
Total : 301
