Aller au contenu principal
Google Chromebook Pixel 2 Back Panel Replacement
Ce dont vous avez besoin
  1. Google Chromebook Pixel 2 Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Back Panel Replacement: étape 2, image 1 de 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Back Panel Replacement: étape 3, image 1 de 2 Google Chromebook Pixel 2 Back Panel Replacement: étape 3, image 2 de 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Back Panel Replacement: étape 4, image 1 de 1
    • Carefully lift the back panel off of the device.
Garrett Monteiro
Membre depuis le 04/26/17
413 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S22-G6, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 membres
3 tutoriels rédigés
Un commentaire
Where can I buy replacements for the rubber strips? They never quite fit again and eventually were coming off and sticking to things, so had to throw them away.
Marc Bernard Schauber - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,398
