Aller au contenu principal
Google Chromebook Pixel 2 Fan Replacement
Ce dont vous avez besoin
  1. Google Chromebook Pixel 2 Fan Replacement, Back Panel: étape 1, image 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Fan Replacement: étape 2, image 1 de 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Fan Replacement: étape 3, image 1 de 2 Google Chromebook Pixel 2 Fan Replacement: étape 3, image 2 de 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Fan Replacement: étape 4, image 1 de 1
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Fan Replacement, Fan: étape 5, image 1 de 2 Google Chromebook Pixel 2 Fan Replacement, Fan: étape 5, image 2 de 2
    • Remove the three blue 4.0 mm Phillips #00 screws from the fan on the right side.
  6. Google Chromebook Pixel 2 Fan Replacement: étape 6, image 1 de 1
    • Using the plastic opening tool, slide out the right fan’s connector out of the motherboard slot.
  7. Google Chromebook Pixel 2 Fan Replacement: étape 7, image 1 de 1
    • Carefully remove lift the right fan out of its slot.
  8. Google Chromebook Pixel 2 Fan Replacement: étape 8, image 1 de 2 Google Chromebook Pixel 2 Fan Replacement: étape 8, image 2 de 2
    • Remove three blue 4.0 mm Phillips #00 screws from the left fan.
  9. Google Chromebook Pixel 2 Fan Replacement: étape 9, image 1 de 1
    • Using the plastic opening tool, slide out the left fan’s connector.
  10. Google Chromebook Pixel 2 Fan Replacement: étape 10, image 1 de 1
    • Gently lift the left fan out of its slot.
Garrett Monteiro
Membre depuis le 04/26/17
413 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S22-G6, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 144
