Aller au contenu principal
Google Home LED Board Replacement
Ce dont vous avez besoin
  1. Google Home LED Board Replacement, Interconnect Cable: étape 1, image 1 de 3 Google Home LED Board Replacement, Interconnect Cable: étape 1, image 2 de 3 Google Home LED Board Replacement, Interconnect Cable: étape 1, image 3 de 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home LED Board Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home LED Board Replacement, LED Board: étape 3, image 1 de 2 Google Home LED Board Replacement, LED Board: étape 3, image 2 de 2
    • Use a metal spudger to pry the LED board away from the lid.
    • This will require some force because there is a strong adhesive layer that keeps the LED board attached to the lid, so don’t worry about being gentle.
    • Remove the LED board.
Gabe Hyun
Membre depuis le 04/17/18
826 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S24-G11, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 747
