Aller au contenu principal
Google Home Mini USB Power Port Replacement
Ce dont vous avez besoin
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: étape 1, image 1 de 1
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: étape 2, image 1 de 1
  3. Google Home Mini USB Power Port Replacement: étape 3, image 1 de 1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: étape 4, image 1 de 1
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: étape 5, image 1 de 1
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: étape 6, image 1 de 2 Google Home Mini USB Power Port Replacement, USB Power Port: étape 6, image 2 de 2
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: étape 7, image 1 de 2 Google Home Mini USB Power Port Replacement: étape 7, image 2 de 2
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: étape 8, image 1 de 2 Google Home Mini USB Power Port Replacement: étape 8, image 2 de 2
    • Remove the board.
9 autres ont terminé cette réparation.
Mia Sulaiman
Membre depuis le 05/21/18
1 032 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 membres
5 tutoriels rédigés
8 commentaires
Where I can buy micro USB PCB ?
so_ang - Réponse
Planet Carl - Réponse
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Réponse
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Réponse
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 14
30 derniers jours : 63
Total : 6,135
