Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 10 Bottom Speaker Replacement
Ce dont vous avez besoin
  1. Google Pixel 10 Bottom Speaker Replacement, Prepare your Pixel for disassembly: étape 1, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Prepare your Pixel for disassembly: étape 1, image 2 de 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 10 Bottom Speaker Replacement, Cracked glass preparation: étape 2, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Cracked glass preparation: étape 2, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Cracked glass preparation: étape 2, image 3 de 3
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
    • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
    • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Demander à FixBot
  3. Google Pixel 10 Bottom Speaker Replacement, Heat the bottom edge: étape 3, image 1 de 1
    • Adhesive secures the back glass to the frame. Heating the glass softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the back glass.
    • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
    Demander à FixBot
  4. Google Pixel 10 Bottom Speaker Replacement, Apply a suction handle: étape 4, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Apply a suction handle: étape 4, image 2 de 2
    • Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
    Demander à FixBot
  5. Google Pixel 10 Bottom Speaker Replacement, Insert an opening pick: étape 5, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Insert an opening pick: étape 5, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Insert an opening pick: étape 5, image 3 de 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
    • Insert the tip of an opening pick into the gap.
    Demander à FixBot
  6. Google Pixel 10 Bottom Speaker Replacement, Back glass adhesive information: étape 6, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Back glass adhesive information: étape 6, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Back glass adhesive information: étape 6, image 3 de 3
    • The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
    • A cable connects the back glass near the power button. Don't insert your pick here to avoid damaging the cable.
    Demander à FixBot
  7. Google Pixel 10 Bottom Speaker Replacement, Separate the bottom edge adhesive: étape 7, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the bottom edge adhesive: étape 7, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the bottom edge adhesive: étape 7, image 3 de 3
    • If the back glass feels stuck at any point when separating the adhesive, apply heat to the area and try again.
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
    Demander à FixBot
  8. Google Pixel 10 Bottom Speaker Replacement, Separate the bottom left adhesive: étape 8, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the bottom left adhesive: étape 8, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the bottom left adhesive: étape 8, image 3 de 3
    • Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
    • Leave the pick inserted to prevent the adhesive from re‑sealing.
    Demander à FixBot
  9. Google Pixel 10 Bottom Speaker Replacement, Separate the right edge adhesive: étape 9, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the right edge adhesive: étape 9, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the right edge adhesive: étape 9, image 3 de 3
    • Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
    • Leave the pick inserted under the top right corner.
    Demander à FixBot
  10. Google Pixel 10 Bottom Speaker Replacement, Separate the top edge adhesive: étape 10, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the top edge adhesive: étape 10, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Separate the top edge adhesive: étape 10, image 3 de 3
    • Insert a fourth pick under the top right corner.
    • Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
    • Don't try to fully remove the back glass yet, as it's still connected by a ribbon cable.
    Demander à FixBot
  11. Google Pixel 10 Bottom Speaker Replacement, Prop up the back glass: étape 11, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Prop up the back glass: étape 11, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Prop up the back glass: étape 11, image 3 de 3
    • Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
    • If the back glass still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
    Demander à FixBot
  12. Google Pixel 10 Bottom Speaker Replacement, Remove the bracket screws: étape 12, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Remove the bracket screws: étape 12, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the back glass connector bracket.
    Demander à FixBot
  13. Google Pixel 10 Bottom Speaker Replacement: étape 13, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 13, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 13, image 3 de 3
    • Use tweezers or your fingers to remove the bracket.
    • Be careful not to scratch or smudge the rear cameras.
    Demander à FixBot
  14. Google Pixel 10 Bottom Speaker Replacement, Disconnect the back glass: étape 14, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Disconnect the back glass: étape 14, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
    Demander à FixBot
  15. Google Pixel 10 Bottom Speaker Replacement, Remove the back glass: étape 15, image 1 de 1
    • Remove the back glass.
    Demander à FixBot
  16. Google Pixel 10 Bottom Speaker Replacement, Remove the bottom speaker screws: étape 16, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Remove the bottom speaker screws: étape 16, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the bottom speaker.
    Demander à FixBot
  17. Google Pixel 10 Bottom Speaker Replacement, Remove the bottom speaker: étape 17, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Remove the bottom speaker: étape 17, image 2 de 2
    • Pull the speaker towards the top of the phone and remove it.
    Demander à FixBot
  18. Google Pixel 10 Bottom Speaker Replacement, Disassembly complete: étape 18, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
    Demander à FixBot
  19. Google Pixel 10 Bottom Speaker Replacement, Install the bottom speaker: étape 19, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Install the bottom speaker: étape 19, image 2 de 2
    • Slide the bottom speaker into place at a slight downward angle so the speaker gasket goes into its cutout.
    • Press the bottom speaker down firmly into its recess.
    Demander à FixBot
  20. Google Pixel 10 Bottom Speaker Replacement: étape 20, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement: étape 20, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the bottom speaker.
    Demander à FixBot
  21. Google Pixel 10 Bottom Speaker Replacement, Remove the old back glass adhesive: étape 21, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Remove the old back glass adhesive: étape 21, image 2 de 2
    • Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
    • Take your time during the next two steps. A clean frame allows replacement adhesive to lay totally flat, ensuring a better seal for your back glass.
    Demander à FixBot
  22. Google Pixel 10 Bottom Speaker Replacement: étape 22, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 22, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 22, image 3 de 3
    • Removing all the old adhesive can be very tricky and time‑consuming.
    • When removing the back glass adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
    • Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
    • If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
    Demander à FixBot
  23. Google Pixel 10 Bottom Speaker Replacement: étape 23, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement: étape 23, image 2 de 2
    • Wrap a microfiber or lint‑free cloth around a spudger and apply a single drop of high‑concentration (>90%) isopropyl alcohol to the end.
    • Use the spudger to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
    • Let the alcohol dry completely before continuing.
    Demander à FixBot
  24. Google Pixel 10 Bottom Speaker Replacement: étape 24, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement: étape 24, image 2 de 2
    • If you're reinstalling your original back glass, repeat the procedures in the previous two steps on the back glass to clean it.
    Demander à FixBot
  25. Google Pixel 10 Bottom Speaker Replacement, Orient the adhesive: étape 25, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Orient the adhesive: étape 25, image 2 de 2
    • Before applying the back glass adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
    Demander à FixBot
  26. Google Pixel 10 Bottom Speaker Replacement: étape 26, image 1 de 1
    • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
    Demander à FixBot
  27. Google Pixel 10 Bottom Speaker Replacement, Install the back glass adhesive: étape 27, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Install the back glass adhesive: étape 27, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Install the back glass adhesive: étape 27, image 3 de 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
    Demander à FixBot
  28. Google Pixel 10 Bottom Speaker Replacement: étape 28, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 28, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 28, image 3 de 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
    Demander à FixBot
  29. Google Pixel 10 Bottom Speaker Replacement: étape 29, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 29, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 29, image 3 de 3
    • Use a spudger to press down firmly on the adhesive to secure it to the frame.
    Demander à FixBot
  30. Google Pixel 10 Bottom Speaker Replacement, Remove the larger liner: étape 30, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Remove the larger liner: étape 30, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Remove the larger liner: étape 30, image 3 de 3
    • Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
    Demander à FixBot
  31. Google Pixel 10 Bottom Speaker Replacement: étape 31, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 31, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement: étape 31, image 3 de 3
    Demander à FixBot
  32. Google Pixel 10 Bottom Speaker Replacement, Remove any liners from the back glass: étape 32, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Remove any liners from the back glass: étape 32, image 2 de 2
    • If you're installing a new back glass, your replacement will have various protective liners and pieces of tape on the underside that must be removed. Your part may have different pieces in different locations, so make sure to check carefully!
    • Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
    • Usually, you can identify the liners by their pull tabs.
    Demander à FixBot
  33. Google Pixel 10 Bottom Speaker Replacement, Prop up the back glass: étape 33, image 1 de 1
    • Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
    • Alternatively, you can use a sturdy object (such as a stack of books) to prop up the back glass.
    Demander à FixBot
  34. Google Pixel 10 Bottom Speaker Replacement, Connect the back glass cable: étape 34, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement, Connect the back glass cable: étape 34, image 2 de 2
    • Use the flat end of a spudger to connect the back glass press connector to its socket.
    • This can be tricky, as there's very little play in the cable. Move the back glass as necessary to help, and don't try to force the connector into place—reposition it and try again.
    Demander à FixBot
  35. Google Pixel 10 Bottom Speaker Replacement, Install the bracket: étape 35, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Install the bracket: étape 35, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Install the bracket: étape 35, image 3 de 3
    • Put the cable's bracket back in place, making sure the tab on the right edge goes under its groove.
    Demander à FixBot
  36. Google Pixel 10 Bottom Speaker Replacement: étape 36, image 1 de 2 Google Pixel 10 Bottom Speaker Replacement: étape 36, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the bracket.
    • This is a good point to power on your device and test all functions before sealing it up. If you have trouble, try some basic troubleshooting. Be sure to power back down completely before you continue working.
    Demander à FixBot
  37. Google Pixel 10 Bottom Speaker Replacement, Remove the remaining liners: étape 37, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Remove the remaining liners: étape 37, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Remove the remaining liners: étape 37, image 3 de 3
    • Remove the remaining liners from the back glass adhesive.
    Demander à FixBot
  38. Google Pixel 10 Bottom Speaker Replacement, Install the back glass: étape 38, image 1 de 3 Google Pixel 10 Bottom Speaker Replacement, Install the back glass: étape 38, image 2 de 3 Google Pixel 10 Bottom Speaker Replacement, Install the back glass: étape 38, image 3 de 3
    • Flip the back glass onto the frame and press it firmly into place.
    • Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
    • For an even stronger bond, you can stack books on the back glass or use screen vise clamps.
    Demander à FixBot
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membre depuis le 09/14/22
196 166 Réputation
1 243 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 122
Total : 606
