Introduction
This is an outdated guide, go here for the newest version.
Use this guide to replace the rear camera in a Pixel 2 XL.
Ce dont vous avez besoin
Étape 1 Opening Procedure
Attention : les étapes 1 à 12 sont issues d'un tutoriel marqué comme en cours.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Use the flat end of a spudger to disconnect the battery connector.
Use tweezers to peel the black tape off of the camera connector.
Disconnect the camera and remove it.
