Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 3 XL Motherboard Replacement
Ce dont vous avez besoin
  1. Google Pixel 3 XL Motherboard Replacement, Heat the edge of the back cover: étape 1, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Heat the edge of the back cover: étape 1, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Heat the edge of the back cover: étape 1, image 3 de 3
    • Heat an iOpener and apply it to the right edge of the back cover for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back cover:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 3 XL Motherboard Replacement, Create a gap under the back cover: étape 2, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Create a gap under the back cover: étape 2, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Create a gap under the back cover: étape 2, image 3 de 3
    • Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Demander à FixBot
  3. Google Pixel 3 XL Motherboard Replacement, Loosen the right edge adhesives: étape 3, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the right edge adhesives: étape 3, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the right edge adhesives: étape 3, image 3 de 3
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
    Demander à FixBot
  4. Google Pixel 3 XL Motherboard Replacement, Heat the bottom edge of the back cover: étape 4, image 1 de 1
    • Apply a heated iOpener to the bottom of the back cover for a minute.
    Demander à FixBot
  5. Google Pixel 3 XL Motherboard Replacement, Slice through the bottom adhesives: étape 5, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Slice through the bottom adhesives: étape 5, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Slice through the bottom adhesives: étape 5, image 3 de 3
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
    Demander à FixBot
  6. Google Pixel 3 XL Motherboard Replacement, Slice through the remaining edges: étape 6, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Slice through the remaining edges: étape 6, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Slice through the remaining edges: étape 6, image 3 de 3
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
    Demander à FixBot
  7. Google Pixel 3 XL Motherboard Replacement, Slice through the leftover adhesive: étape 7, image 1 de 1
    • Gently pry up the right edge of the back cover.
    • Use an opening pick to slice through any remaining adhesive along the edges.
    Demander à FixBot
  8. Google Pixel 3 XL Motherboard Replacement, Swing open the back cover: étape 8, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Swing open the back cover: étape 8, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Swing open the back cover: étape 8, image 3 de 3
    • Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back cover.
    • If you replaced the fingerprint sensor, you'll need to use this software tool to make the phone recognize the new sensor.
    Demander à FixBot
  9. Google Pixel 3 XL Motherboard Replacement, Remove the fingerprint sensor tape: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
    Demander à FixBot
  10. Google Pixel 3 XL Motherboard Replacement, Disconnect the fingerprint sensor: étape 10, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Disconnect the fingerprint sensor: étape 10, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Disconnect the fingerprint sensor: étape 10, image 3 de 3
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
    Demander à FixBot
  11. Google Pixel 3 XL Motherboard Replacement, Remove the back cover: étape 11, image 1 de 1
    • Remove the back cover.
    • Follow this guide to correctly apply new back cover adhesive.
    Demander à FixBot
  12. Google Pixel 3 XL Motherboard Replacement, Remove the metal cover bracket screws: étape 12, image 1 de 1
    Magnetic Project Mat
    $19.95
    • Remove the following four T3 screws securing the metal cover bracket:
    • Three 4 mm long screws
    • One 3 mm long screw
    Demander à FixBot
  13. Google Pixel 3 XL Motherboard Replacement, Remove the metal cover bracket: étape 13, image 1 de 2 Google Pixel 3 XL Motherboard Replacement, Remove the metal cover bracket: étape 13, image 2 de 2
    • Insert the flat end of a spudger underneath the top right edge of the metal bracket and pry up to loosen it.
    • Remove the metal cover bracket.
    Demander à FixBot
  14. Google Pixel 3 XL Motherboard Replacement, Disconnect the battery: étape 14, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Disconnect the battery: étape 14, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Disconnect the battery: étape 14, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
    • Do not use metal tools to to disconnect the battery, or you will risk shorting the battery.
    • Bend the battery cable such that the connector will not accidentally touch the socket.
    Demander à FixBot
  15. Google Pixel 3 XL Motherboard Replacement, Remove the motherboard shield screws: étape 15, image 1 de 1
    • Remove the five T3 screws securing the motherboard shield:
    • Two 3 mm long screws
    Demander à FixBot
  16. Google Pixel 3 XL Motherboard Replacement, Remove the motherboard shield: étape 16, image 1 de 1
    • Remove the motherboard shield.
    Demander à FixBot
  17. Google Pixel 3 XL Motherboard Replacement, Remove the front camera bracket: étape 17, image 1 de 1
    • Remove the three 3 mm long T3 screws securing the front camera bracket.
    Demander à FixBot
  18. Google Pixel 3 XL Motherboard Replacement, Remove the front camera bracket: étape 18, image 1 de 1
    • Remove the front camera bracket.
    Demander à FixBot
  19. Google Pixel 3 XL Motherboard Replacement, Disconnect the front cameras: étape 19, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Disconnect the front cameras: étape 19, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Disconnect the front cameras: étape 19, image 3 de 3
    • Use the point of a spudger to carefully pry up and disconnect the cameras from their motherboard sockets.
    • Be very careful not to dislodge the small surface-mounted components surrounding the sockets.
    Demander à FixBot
  20. Google Pixel 3 XL Motherboard Replacement, Loosen the front cameras: étape 20, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the front cameras: étape 20, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the front cameras: étape 20, image 3 de 3
    • The cameras are lightly adhered in place.
    • Use the flat end of a spudger to pry up and loosen the camera modules from their recess.
    Demander à FixBot
  21. Google Pixel 3 XL Motherboard Replacement, Remove the front-facing cameras: étape 21, image 1 de 1
    • Remove the front-facing cameras.
    Demander à FixBot
  22. Google Pixel 3 XL Motherboard Replacement, Remove one loudspeaker screw: étape 22, image 1 de 1
    • Remove the 4 mm long T3 screw securing the top-right corner of the loudspeaker.
    • Removing this screw will give you slightly more wiggle room when removing the motherboard.
    Demander à FixBot
  23. Google Pixel 3 XL Motherboard Replacement, Remove the button array connector bracket: étape 23, image 1 de 1
    • Remove the two 3 mm long T3 screws securing the button array connector bracket.
    Demander à FixBot
  24. Google Pixel 3 XL Motherboard Replacement: étape 24, image 1 de 1
    • Remove the button array connector bracket.
    Demander à FixBot
  25. Google Pixel 3 XL Motherboard Replacement, Disconnect the earpiece speaker: étape 25, image 1 de 2 Google Pixel 3 XL Motherboard Replacement, Disconnect the earpiece speaker: étape 25, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the earpiece connector from its motherboard socket.
    • Carefully remove the connector pad surrounding the earpiece socket.
    Demander à FixBot
  26. Google Pixel 3 XL Motherboard Replacement, Disconnect the motherboard connectors: étape 26, image 1 de 1
    • Use the point of a spudger to pry up and disconnect the following:
    • Microphone connector
    • Button array connector
    • Earpiece connector (should already be disconnected)
    Demander à FixBot
  27. Google Pixel 3 XL Motherboard Replacement: étape 27, image 1 de 2 Google Pixel 3 XL Motherboard Replacement: étape 27, image 2 de 2
    • Charging coil connector
    • Left squeeze sensor connector
    • Display connector
    • Right squeeze sensor connector
    • Loudspeaker connector
    • USB-C port connector
    Demander à FixBot
  28. Google Pixel 3 XL Motherboard Replacement, Remove the motherboard screws: étape 28, image 1 de 1
    • Remove the two 3 mm long T3 screws securing the motherboard.
    Demander à FixBot
  29. Google Pixel 3 XL Motherboard Replacement, Loosen the motherboard: étape 29, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the motherboard: étape 29, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the motherboard: étape 29, image 3 de 3
    • Insert the point of a spudger underneath the motherboard, near the rear-facing camera module.
    • Pry up gently to loosen the motherboard from its recess.
    • If the motherboard is not budging, make sure you have disconnected all the connectors.
    • The motherboard has to squeeze past the earpiece speaker cable. If too much pressure is put on the earpiece cable, the earpiece speaker will pop open. You can prevent this by pressing on the earpiece module with a finger while you maneuver the motherboard out.
    • If the earpiece speaker pops open (as shown in the third photo of this step), carefully align and press the module back in place.
    Demander à FixBot
  30. Google Pixel 3 XL Motherboard Replacement: étape 30, image 1 de 3 Google Pixel 3 XL Motherboard Replacement: étape 30, image 2 de 3 Google Pixel 3 XL Motherboard Replacement: étape 30, image 3 de 3
    • Don't attempt to remove the motherboard from the phone. It's still attached to the phone.
    • While you perform this step, take care to keep slack on the antenna cables attached to the bottom leg of the motherboard.
    • Lift the top half of the motherboard slightly to clear the board from its recess.
    • Twist the left edge of the board over and out of the phone and rest the board on the right edge of the phone.
    Demander à FixBot
  31. Google Pixel 3 XL Motherboard Replacement, Loosen the antenna cables: étape 31, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the antenna cables: étape 31, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Loosen the antenna cables: étape 31, image 3 de 3
    • Use the flat of a spudger to gently pry up and loosen the black and white antenna cables from their motherboard clips.
    • The cables are fragile and the clips hold onto them tightly. Be patient and pry as close to the base of the clips as possible.
    Demander à FixBot
  32. Google Pixel 3 XL Motherboard Replacement, Remove the motherboard: étape 32, image 1 de 1
    • Remove the motherboard.
    Demander à FixBot
  33. Google Pixel 3 XL Motherboard Replacement, Transfer the rear-facing camera: étape 33, image 1 de 3 Google Pixel 3 XL Motherboard Replacement, Transfer the rear-facing camera: étape 33, image 2 de 3 Google Pixel 3 XL Motherboard Replacement, Transfer the rear-facing camera: étape 33, image 3 de 3
    • If you are installing a new motherboard, follow these instructions to transfer the rear-facing camera:
    • Use the point of a spudger to pry up and disconnect the rear-facing camera from its motherboard socket.
    • Remove the rear-facing camera and transfer it to your replacement motherboard.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
11 autres ont terminé cette réparation.
Arthur Shi
Membre depuis le 01/03/18
343 607 Réputation
915 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
27 624 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 50
Total : 11,509
