Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 4 Front Camera and Sensor Assembly Replacement
Ce dont vous avez besoin
  1. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the SIM card tray: étape 1, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the SIM card tray: étape 1, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the SIM card tray: étape 1, image 3 de 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Heat the back panel glass: étape 2, image 1 de 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Apply a suction cup: étape 3, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Apply a suction cup: étape 3, image 2 de 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Insert an opening pick: étape 4, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Insert an opening pick: étape 4, image 2 de 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Begin to slice the adhesive: étape 5, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Begin to slice the adhesive: étape 5, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Begin to slice the adhesive: étape 5, image 3 de 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice the lefthand-side adhesive: étape 6, image 1 de 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 7, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 7, image 2 de 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 8, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 8, image 2 de 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice righthand-side adhesive: étape 9, image 1 de 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 10, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 10, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 10, image 3 de 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice the top-side adhesive: étape 11, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice the top-side adhesive: étape 11, image 2 de 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Lift up the back panel: étape 12, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Lift up the back panel: étape 12, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Lift up the back panel: étape 12, image 3 de 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 13, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 13, image 2 de 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the battery: étape 14, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  15. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 15, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 15, image 2 de 2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 16, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 16, image 2 de 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 17, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 17, image 2 de 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the back panel connector: étape 18, image 1 de 1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 19, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 19, image 2 de 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 20, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 20, image 2 de 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the back panel: étape 21, image 1 de 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Front Camera and Sensor Assembly: étape 22, image 1 de 1
    • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
  23. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 23, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 23, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 23, image 3 de 3
    • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
  24. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the camera and sensor connectors: étape 24, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the camera and sensor connectors: étape 24, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the camera and sensor connectors: étape 24, image 3 de 3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  25. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 25, image 1 de 2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 25, image 2 de 2
    • Disconnect the laser module connector.
  26. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the front camera and sensor assembly: étape 26, image 1 de 1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
  27. Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 27, image 1 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 27, image 2 de 3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: étape 27, image 3 de 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Carsten Frauenheim
Membre depuis le 03/10/20
157 361 Réputation
439 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 918 tutoriels rédigés
5 commentaires de tutoriel
Does face id feature work after a replacement?
Weber Lev - Réponse
It’s not an iPhone, so I’d say yes.
Skylar Ittner -
I've replaced my Pixel 4 XL front camera as instruction; but unfortunately,my face ID doesn't work after replacement. It kept showing "Enrolment was not completed. Certificate expired."
Kien Mach - Réponse
if i do replace this module did the face id works ??
abdeljalil megaache - Réponse
i change my cpu and then the face id didnt work, what should i do?
Ahmad Dzaki - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 47
30 derniers jours : 220
Total : 4,002
