Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 8a Loudspeaker Replacement
Ce dont vous avez besoin
    1. Google Pixel 8a Loudspeaker Replacement, Prepare your Pixel for disassembly: étape 1, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Prepare your Pixel for disassembly: étape 1, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Prepare your Pixel for disassembly: étape 1, image 3 de 3
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Completely power off your phone.
      • Press the power and volume up buttons at the same time to bring up the shutdown menu.
      Demander à FixBot
      Ajouter un commentaire
    1. Google Pixel 8a Loudspeaker Replacement, Remove the SIM card tray: étape 2, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Remove the SIM card tray: étape 2, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Remove the SIM card tray: étape 2, image 3 de 3
      • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
      • Remove the SIM card tray.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Adhesive information: étape 3, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Adhesive information: étape 3, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Adhesive information: étape 3, image 3 de 3
      • The back cover is secured with adhesive around the perimeter and near the cameras. To avoid damaging your phone's internals, note the following:
      • Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
      • Don't insert your tool under the edges of the camera bump.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement, Insert an opening tool: étape 4, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Insert an opening tool: étape 4, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Insert an opening tool: étape 4, image 3 de 3
      • Your opening tool has a flat end and a curved end. During the opening procedure, use the flat end and angle it so the tool's sharp edge points upward.
      • Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
      Demander à FixBot
    3. Google Pixel 8a Loudspeaker Replacement, Separate the perimeter adhesive: étape 5, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Separate the perimeter adhesive: étape 5, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Separate the perimeter adhesive: étape 5, image 3 de 3
      • Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
      Demander à FixBot
    4. Google Pixel 8a Loudspeaker Replacement: étape 6, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 6, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 6, image 3 de 3
      • Slide your opening tool around the bottom right corner and up the right edge, stopping at the bottom of the camera bump.
      • Remove your opening tool from under the back cover.
      Demander à FixBot
    5. Google Pixel 8a Loudspeaker Replacement: étape 7, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 7, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 7, image 3 de 3
      • Insert your opening tool under the top right corner of the back cover, just above the camera bump.
      • Slide your opening tool along the top edge, stopping at the top left corner just above the camera bump.
      Demander à FixBot
    6. Google Pixel 8a Loudspeaker Replacement: étape 8, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 8, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 8, image 3 de 3
      • Insert your opening tool under the left edge of the back cover, just below the camera bump.
      • Slide your opening tool down the left edge to separate the adhesive.
      Demander à FixBot
    7. Google Pixel 8a Loudspeaker Replacement, Separate the camera bump adhesive: étape 9, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Separate the camera bump adhesive: étape 9, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Separate the camera bump adhesive: étape 9, image 3 de 3
      • A strip of adhesive above the camera bump secures the top edge of the back cover.
      • Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
      • You can insert the opening pick more than 3 mm along the top edge.
      • Slide the pick to the right, stopping when you reach the right edge of the cameras.
      Demander à FixBot
    8. Google Pixel 8a Loudspeaker Replacement: étape 10, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 10, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 10, image 3 de 3
      • A final strip of adhesive below the camera bump secures the back cover.
      • Insert the flat edge of an opening pick under the back cover, just below the camera bump.
      • Insert a second opening pick in the same spot on the other side.
      Demander à FixBot
    9. Google Pixel 8a Loudspeaker Replacement: étape 11, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 11, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 11, image 3 de 3
      • Pry up simultaneously with both picks and apply constant pressure to separate the final piece of adhesive securing the back cover.
      • Be careful not to bend the back cover. If the adhesive feels stubborn, rotate the cover side-to-side to further loosen the adhesive.
      • If the adhesive isn't separating, you can lightly heat the back cover just below the camera bump with a hair dryer or iOpener to soften the adhesive.
      Demander à FixBot
    10. Google Pixel 8a Loudspeaker Replacement, Remove the back cover: étape 12, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Remove the back cover: étape 12, image 2 de 2
      • Remove the back cover.
      • During reassembly:
      • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
      • Follow this guide to apply new adhesive and install your back cover.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Separate the flash unit: étape 13, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Separate the flash unit: étape 13, image 2 de 2
      • Use a hair dryer to heat the flash unit to soften the adhesive securing it to the logic board cover.
      • Alternatively, you can use an iOpener or heat gun to warm the flash.
      • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement: étape 14, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 14, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 14, image 3 de 3
      • Slide your pick under the top edge of the flash and lift to separate the adhesive securing it to the cover.
      • Be careful not to slip and tear the flash cable, as it's very fragile.
      • During reassembly, follow this guide to replace the flash adhesives.
      Demander à FixBot
    3. Google Pixel 8a Loudspeaker Replacement, Unclip the logic board cover: étape 15, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Unclip the logic board cover: étape 15, image 2 de 2
      Outil utilisé dans cette étape :
      FixMat
      $36.95
      • While the Pixel 8a uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP screwdriver to remove the 15 screws securing the logic board cover:
      • Thirteen 4.3 mm‑long screws
      • Two 1.9 mm‑long screws
      Demander à FixBot
    4. Google Pixel 8a Loudspeaker Replacement: étape 16, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 16, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 16, image 3 de 3
      • Be very careful not to damage the spring contacts around your phone's perimeter. Only insert your tool where instructed.
      • Insert an opening pick under the bottom right corner of the logic board cover and pry up to release the clip.
      • Insert the tip of a spudger under the notch near the top right corner of the logic board cover (just below the screw hole) and pry up to release the clip.
      Demander à FixBot
    5. Google Pixel 8a Loudspeaker Replacement: étape 17, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 17, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 17, image 3 de 3
      • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
      • During reassembly, thread the flash through its cutout as you lower the logic board cover into place.
      Demander à FixBot
    6. Google Pixel 8a Loudspeaker Replacement, Remove the wireless charging assembly: étape 18, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Remove the wireless charging assembly: étape 18, image 2 de 2
      • Remove the logic board cover (which has the wireless charging coil connected to it).
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Disconnect the battery: étape 19, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Disconnect the battery: étape 19, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Disconnect the battery: étape 19, image 3 de 3
      • Use a pair of tweezers or your fingers to remove the metal cover on the right edge of your phone.
      • During reassembly, place the upper left corner of the cover under the hook on the logic board before laying it into place.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement: étape 20, image 1 de 1
      • This guide was shot with the Verizon model (G8HHN) Google Pixel 8a, which has an extra cable and connector for the 5G mmWave antenna (just to the left of the battery connector). If you have the non-mmWave model, just skip any steps that mention the antenna cable.
      Demander à FixBot
    3. Google Pixel 8a Loudspeaker Replacement: étape 21, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 21, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 21, image 3 de 3
      • Insert the flat end of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
      • To prevent damaging the surface mounted components around the battery and 5G mmWave connectors, only pry where instructed.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Disconnect the 5G mmWave antenna: étape 22, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Disconnect the 5G mmWave antenna: étape 22, image 2 de 2
      • Insert the point of a spudger under the bottom edge of the 5G mmWave antenna press connector and pry straight up to disconnect it.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Remove the earpiece speaker: étape 23, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Remove the earpiece speaker: étape 23, image 2 de 2
      • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the earpiece speaker to the frame.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement: étape 24, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 24, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 24, image 3 de 3
      • Lift the bottom edge of the earpiece speaker and remove it.
      • When reinserting the speaker during reassembly, make sure the graphite film is out of the way. Then, insert the speaker at a downward angle and push it towards the front of the phone so the gasket goes into its cutout in the frame.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Remove the antenna housing: étape 25, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Remove the antenna housing: étape 25, image 2 de 2
      • Use a Torx Plus 3IP screwdriver to remove the two 4.3 mm‑long screws securing the antenna housing.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement: étape 26, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 26, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 26, image 3 de 3
      • Insert an opening pick under the left edge of the antenna housing and pry up to release the clips securing the housing.
      • Repeat the process on the top edge to release the remaining clips.
      • During reassembly, press firmly around the perimeter of the housing to engage its clips.
      Demander à FixBot
    3. Google Pixel 8a Loudspeaker Replacement: étape 27, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 27, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 27, image 3 de 3
      • Lift the antenna housing and remove it.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Disconnect the logic board: étape 28, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Disconnect the logic board: étape 28, image 2 de 2
      • Be careful not to touch the rear camera lenses during the next two steps.
      • Use the point of a spudger or your fingernail to pry up and disconnect the press connector just above the battery.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement: étape 29, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 29, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 29, image 3 de 3
      • Slide the tip of your opening pick under the right edge of the front-facing camera cable and lift to detach it.
      • If the pick can't slide under the cable, lightly heat the cable with a hair dryer or heat gun to soften the adhesive underneath.
      Demander à FixBot
    3. Google Pixel 8a Loudspeaker Replacement: étape 30, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 30, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 30, image 3 de 3
      • Move the battery and 5G mmWave cables out of the way of the battery.
      Demander à FixBot
    4. Google Pixel 8a Loudspeaker Replacement: étape 31, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 31, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 31, image 3 de 3
      Demander à FixBot
    5. Google Pixel 8a Loudspeaker Replacement: étape 32, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 32, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 32, image 3 de 3
      • The logic board is delicate. Be careful not to bend it as you free the lower edge from the frame.
      • Before trying to remove the board, make sure you removed the SIM tray.
      • Lift the top edge of the logic board from the frame.
      • Pull the top edge of the logic board to the right of the frame so the cutouts of the board lift over the vibration motor and protrusions in the frame.
      • As you pull, guide the charging port out of its recess in the frame.
      • Don't fully remove the logic board yet, as it's still connected to the frame by the screen cable.
      • During reassembly, push the logic board toward the bottom of the frame and press the charging port down until the bottom edge sits flush with its protrusion in the frame.
      • Make sure the flash, front-facing camera, and press connector don't become trapped under the frame.
      Demander à FixBot
    6. Google Pixel 8a Loudspeaker Replacement, Prop up your phone: étape 33, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Prop up your phone: étape 33, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Prop up your phone: étape 33, image 3 de 3
      • The logic board might fall out of place during this step. Hold it steady, but avoid gripping it by any of the camera lenses or connectors.
      • Apply a suction handle to the left side of the screen with the handle facing down.
      • Prop up the left side of your phone so it stands upright.
      • If you don't have a suction handle, prop up the phone against a sturdy object, such as a heavy box or thick book.
      • Tilt the logic board down and lay it flat, gently guiding the delicate graphite sheet around the cables.
      • Be careful not to touch the thermal pads on the underside of the logic board.
      Demander à FixBot
    7. Google Pixel 8a Loudspeaker Replacement: étape 34, image 1 de 3 Google Pixel 8a Loudspeaker Replacement: étape 34, image 2 de 3 Google Pixel 8a Loudspeaker Replacement: étape 34, image 3 de 3
      • Be very careful not to puncture the battery during this step.
      • Hold one hand above the display bracket when prying it up, as the bracket can easily eject.
      • Use the tip of one arm of your angled tweezers to pry up the top edge of the display cable bracket from the center of the logic board.
      • Be very careful not to damage the board under the bracket's socket. Only insert your tweezers just enough to pry up the bracket.
      • Remove the bracket.
      • During reassembly, hook the bottom edge of the bracket into its slot on the logic board and press down firmly on the top to snap the bracket back into place.
      • If your display cable bracket is bent and doesn't fit, replace it with a new one.
      Demander à FixBot
    8. Google Pixel 8a Loudspeaker Replacement: étape 35, image 1 de 2 Google Pixel 8a Loudspeaker Replacement: étape 35, image 2 de 2
      • Insert the flat end of a spudger or a clean fingernail under the top edge of the display cable press connector and pry straight up to disconnect it.
      • The tension in this cable makes it tricky to reconnect. If necessary, hold the neck of the cable in place with tweezers and align it over the socket before pressing down to secure it.
      Demander à FixBot
    9. Google Pixel 8a Loudspeaker Replacement, Remove the logic board: étape 36, image 1 de 2 Google Pixel 8a Loudspeaker Replacement, Remove the logic board: étape 36, image 2 de 2
      • Remove the logic board from the frame.
      Demander à FixBot
    10. Google Pixel 8a Loudspeaker Replacement, Check the front sensor gasket: étape 37, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Check the front sensor gasket: étape 37, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Check the front sensor gasket: étape 37, image 3 de 3
      • If the front sensor rubber gasket stayed on the frame or became misaligned, remove it and set it aside.
      • During reassembly, place the gasket over the front sensor on the logic board, with the smaller cutout toward the top.
      • Avoid touching the sensor with your fingers or tool.
      Demander à FixBot
    11. Google Pixel 8a Loudspeaker Replacement, Check the thermal pads: étape 38, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Check the thermal pads: étape 38, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Check the thermal pads: étape 38, image 3 de 3
      • Check the condition of the thermal pads—they'll be on the bottom of the logic board or the corresponding spot on the right side of the frame.
      • If you're reusing your logic board and either of the thermal pads are damaged, remove the old pad, clean the surface with highly-concentrated isopropyl alcohol (over 90%), and apply a new pad.
      • If you have a new logic board and it doesn't come with thermal pads pre-installed, apply the new pads now.
      Demander à FixBot
    1. Google Pixel 8a Loudspeaker Replacement, Remove the loudspeaker: étape 39, image 1 de 3 Google Pixel 8a Loudspeaker Replacement, Remove the loudspeaker: étape 39, image 2 de 3 Google Pixel 8a Loudspeaker Replacement, Remove the loudspeaker: étape 39, image 3 de 3
      • Don't pry against the battery during this step. Only insert your tool where instructed, and double-check that it's not wedged against the battery.
      • Insert the tip of an opening pick in the gap between the top edge of the loudspeaker and the metal protrusion on the frame.
      • Make sure your tool is between the metal protrusion and the loudspeaker, and not against the battery.
      • Pry the loudspeaker up to separate it from the frame.
      Demander à FixBot
    2. Google Pixel 8a Loudspeaker Replacement: étape 40, image 1 de 2 Google Pixel 8a Loudspeaker Replacement: étape 40, image 2 de 2
      • Remove the loudspeaker.
      • During reassembly, firmly press the loudspeaker back into its recess until it snaps into place.
      Demander à FixBot
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
2 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
198 650 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
58 162 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 41
30 derniers jours : 123
Total : 2,454
